Space-Time Hierarchical Radiosity with Clustering and Higher-Order Wavelets - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Journal Articles Computer Graphics Forum Year : 2004
We address in this paper the issue of computing diffuse global illumination solutions for animation sequences. The principal difficulties lie in the computational complexity of global illumination, emphasized by the movement of objects and the large number of frames to compute, as well as the potential for creating temporal discontinuities in the illumination, a particularly noticeable artifact. We demonstrate how space-time hierarchical radiosity, i.e. the application to the time dimension of a hierarchical decomposition algorithm, can be effectively used to obtain smooth animations: first by proposing the integration of spatial clustering in a space-time hierarchy; second, by using a higher-order wavelet basis adapted for the temporal dimension. The resulting algorithm is capable of creating time-dependent radiosity solutions efficiently.
STHR.pdf (392.17 Ko) Télécharger le fichier
Format : Figure, Image
Dates and versions
inria-00379367 , version 1 (28-04-2009)
Identifiers
Cite
Cyrille Damez, Nicolas Holzschuch, François X. Sillion. Space-Time Hierarchical Radiosity with Clustering and Higher-Order Wavelets. Computer Graphics Forum, 2004, 23 (2), pp.129 - 141. ⟨10.1111/j.1467-8659.2004.00747.x⟩. ⟨inria-00379367⟩
444 View
460 Download
Share
