A dG method for the Stokes equations related to nonconforming approximations - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
We study a discontinuous Galerkin method for the Stokes equations with a new stabilization of the viscous term. On the one hand, it allows us to recover, as the stabilization parameter tends towards infinity, some stable and well-known nonconforming approximations of the Stokes problem. On the other hand, we can easily define an a posteriori error indicator, based on the reconstruction of a locally conservative H(div)-tensor. An a priori error analysis is also carried out, yielding optimal convergence rates. Numerical tests illustrating the accuracy and the robustness of the scheme are presented.
rapport_inria2.pdf (1.33 Mo) Télécharger le fichier
inria-00380772 , version 1 (04-05-2009)
inria-00380772 , version 2 (15-05-2009)
inria-00380772 , version 3 (30-07-2009)
  • HAL Id : inria-00380772 , version 1
Roland Becker, Daniela Capatina, Julie Joie. A dG method for the Stokes equations related to nonconforming approximations. [Research Report] 2009, pp.34. ⟨inria-00380772v1⟩
181 Consultations
262 Téléchargements
