Forcing-based cut-elimination for Gentzen-style intuitionistic sequent calculus - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
We give a simple intuitionistic completeness proof of Kripke semantics for intuitionistic logic with implication and universal quantification with respect to cut-free intuitionistic sequent calculus. The Kripke semantics is ``simplified'' in the way that the domain remains constant. The proof has been formalised in the Coq proof assistant and by combining soundness with completeness, we obtain an executable cut-elimination procedure. The proof easily extends to the case of the absurdity connective using Kripke models with exploding nodes à la Veldman.
wollic-HerLee09-kripke-cut-elim.pdf (118.71 Ko) Télécharger le fichier
inria-00381554 , version 1 (05-05-2009)
  • HAL Id : inria-00381554 , version 1
Hugo Herbelin, Gyesik Lee. Forcing-based cut-elimination for Gentzen-style intuitionistic sequent calculus. Workshop on Logic, Language, Information and Computation, Jun 2009, Tokyo, Japan. pp.209-217. ⟨inria-00381554⟩
173 Consultations
318 Téléchargements
