Parallel Simulation of Complex Unsteady Flows with Variational Multiscale LES and Hybrid RANS/LES - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Reports (Research Report) Year : 2009
We study a new hybrid RANS/Variational Multiscale LES (VMS-LES) model for bluff body flows. The simulations have been carried out using a parallelized solver, based on a mixed \textcolor{Black}{finite} element/\textcolor{Black}{finite} volume formulation on unstructured grids. Parallel performances are analysed. The behavior of a VMS-LES model with different subgrid scale models is investigated for the flow past a circular cylinder at Reynolds number {\it Re} =3900. Second, a new strategy for blending RANS and LES methods in a hybrid model is described and applied to the simulation of the flow around a circular cylinder at {\it Re} = 140000.
RR-6917.pdf (480.4 Ko) Télécharger le fichier
Dates and versions
inria-00381570 , version 1 (05-05-2009)
Identifiers
  • HAL Id : inria-00381570 , version 1
Cite
Hilde Ouvrard, Bruno Koobus, Maria Vittoria Salvetti, Simone Camarri, Stephen F. Wornom, et al.. Parallel Simulation of Complex Unsteady Flows with Variational Multiscale LES and Hybrid RANS/LES. [Research Report] RR-6917, INRIA. 2009, pp.17. ⟨inria-00381570⟩
196 View
62 Download
Share
