An analysis of the impact of multi-threading on communication performance - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Although processors become massively multicore and therefore new programming models mix message passing and multi-threading, the effects of threads on communication libraries remain neglected. Designing an efficient modern communication library requires precautions in order to limit the impact of thread-safety mechanisms on performance. In this paper, we present various approaches to building a thread-safe communication library and we study their benefit and impact on performance. We also describe and evaluate techniques used to exploit idle cores to balance the communication library load across multicore machines.
main.pdf (99.04 Ko) Télécharger le fichier
inria-00381670 , version 1 (06-05-2009)
François Trahay, Elisabeth Brunet, Alexandre Denis. An analysis of the impact of multi-threading on communication performance. Communication Architecture for Clusters, May 2009, Rome, Italy. ⟨10.1109/IPDPS.2009.5160893⟩. ⟨inria-00381670⟩
143 Consultations
534 Téléchargements
