An $L (1/3)$ Discrete Logarithm Algorithm for Low Degree Curves - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2009
We present an algorithm for solving the discrete logarithm problem in Jacobians of families of plane curves whose degrees in $X$ and $Y$ are low with respect to their genera. The finite base fields $\FF_q$ are arbitrary, but their sizes should not grow too fast compared to the genus. For such families, the group structure and discrete logarithms can be computed in subexponential time of $L_{q^g}(1/3, O(1))$. The runtime bounds rely on heuristics similar to the ones used in the number field sieve or the function field sieve.
L13.pdf (207.63 Ko) Télécharger le fichier
inria-00383941 , version 1 (13-05-2009)
inria-00383941 , version 2 (20-12-2009)
  • HAL Id : inria-00383941 , version 1
  • ARXIV : 0905.2177
Andreas Enge, Pierrick Gaudry, Emmanuel Thomé. An $L (1/3)$ Discrete Logarithm Algorithm for Low Degree Curves. 2009. ⟨inria-00383941v1⟩
484 Consultations
318 Téléchargements
