Influence of a rough thin layer on the steady-state potential - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
In this paper, we study the behavior of the steady-state voltage potentials in a material composed by an interior medium surrounded by a rough thin layer and embedded in an ambient bounded medium. The roughness of the layer is supposed to be $\eps$--periodic, $\eps$ being the small thickness of the layer. We present and validate numerically the rigorous approximate transmissions proved by Ciuperca, Jai and Poignard. This paper extends previous works in which the layer had a constant thickness.
RR-6935.pdf (208.91 Ko) Télécharger le fichier
inria-00384198 , version 1 (14-05-2009)
inria-00384198 , version 2 (06-08-2009)
  • HAL Id : inria-00384198 , version 1
Ionel Sorin Ciuperca, Ronan Perrussel, Clair Poignard. Influence of a rough thin layer on the steady-state potential. [Research Report] RR-6935, 2009, pp.11. ⟨inria-00384198v1⟩
581 Consultations
198 Téléchargements
