OpenTURNS, an Open Source initiative to Treat Uncertainties, Risks'N Statistics in a structured industrial approach - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Anne Dutfoy
  • Fonction : Auteur
EDF
Ivan Dutka-Malen
  • Fonction : Auteur
EDF
Alberto Pasanisi
  • Fonction : Auteur
EDF
Régis Lebrun
  • Fonction : Auteur
Fabien Mangeant
  • Fonction : Auteur
Maurice Pendola
  • Fonction : Auteur
Thierry Yalamas
  • Fonction : Auteur
The need to assess robust performance for complex systems have led to a considerable rise of industrial interest in the simulation challenges to treat and propagate uncertainty through complex physical and numerical simulation frameworks. The industrial stakes require that both the methodology and the numerical methods for uncertainty treatment have to be openly validated and enriched both by the academic world and the certification authorities. A general methodology has emerged from the joint effort of both industrial companies and academic institutions, and a list of well-established numerical methods have been selected to support this methodology. EDF R&D, EADS Innovation Works and PhiMECA have developed an Open Source software platform dedicated to uncertainty treatment by probabilistic methods, named OpenTURNS for Open source Treatment of Uncertainty, Risk ‘N Statistics.
p150.pdf (170.74 Ko) Télécharger le fichier
inria-00386719 , version 1 (22-05-2009)
  • HAL Id : inria-00386719 , version 1
Anne Dutfoy, Ivan Dutka-Malen, Alberto Pasanisi, Régis Lebrun, Fabien Mangeant, et al.. OpenTURNS, an Open Source initiative to Treat Uncertainties, Risks'N Statistics in a structured industrial approach. 41èmes Journées de Statistique, SFdS, Bordeaux, 2009, Bordeaux, France, France. ⟨inria-00386719⟩
450 Consultations
475 Téléchargements
