Modeling reducibility on ground terms using constraints - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
In this note, we explain how to model (ir)reducibility of rewriting on ground terms using (dis)equational constraints. We show in particular that innermost (ir)reducibility can be modeled with a particular narrowing relation and that (dis)equational constraints are issued from the most general unifiers of this narrowing relation.
note-HAL.pdf (115.55 Ko) Télécharger le fichier
inria-00387058 , version 1 (22-05-2009)
  • HAL Id : inria-00387058 , version 1
Isabelle Gnaedig, Hélène Kirchner. Modeling reducibility on ground terms using constraints. [Research Report] 2009, pp.9. ⟨inria-00387058⟩
90 Consultations
63 Téléchargements
