Modeling reducibility on ground terms using constraints
In this note, we explain how to model (ir)reducibility of rewriting on ground terms using (dis)equational constraints. We show in particular that innermost (ir)reducibility can be modeled with a particular narrowing relation and that (dis)equational constraints are issued from the most general unifiers of this narrowing relation.
