s'authentifier
version française rss feed
inria-00388481, version 1
Single Scattering in Refractive Media with Triangle Mesh Boundaries
Bruce Walter a1, Shuang Zhao a2, Nicolas Holzschuch () b3, Kavita Bala a12
ACM Transactions on Graphics 28, 3 (2009)
Résumé : Light scattering in refractive media is an important optical phenomenon for computer graphics. While recent research has focused on multiple scattering, there has been less work on accurate solutions for single or low-order scattering. Refraction through a complex boundary allows a single external source to be visible in multiple directions internally with different strengths; these are hard to find with existing techniques. Light scattering in refractive media is an important optical phenomenon for computer graphics. While recent research has focused on multiple scattering, there has been less work on accurate solutions for single or low-order scattering. Refraction through a complex boundary allows a single external source to be visible in multiple directions internally with different strengths; these are hard to find with existing techniques.
  • Domaine : Informatique/Synthèse d'image et réalité virtuelle
  • inria-00388481, version 1
  • oai:hal.inria.fr:inria-00388481
  • Contributeur :
  • Soumis le : Mardi 26 Mai 2009, 17:22:28
  • Dernière modification le : Vendredi 1 Octobre 2010, 12:59:41
tous les articles de la base du CCSd...
