Single Scattering in Refractive Media with Triangle Mesh Boundaries - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2009
Light scattering in refractive media is an important optical phenomenon for computer graphics. While recent research has focused on multiple scattering, there has been less work on accurate solutions for single or low-order scattering. Refraction through a complex boundary allows a single external source to be visible in multiple directions internally with different strengths; these are hard to find with existing techniques. Light scattering in refractive media is an important optical phenomenon for computer graphics. While recent research has focused on multiple scattering, there has been less work on accurate solutions for single or low-order scattering. Refraction through a complex boundary allows a single external source to be visible in multiple directions internally with different strengths; these are hard to find with existing techniques.
amber.pdf (565.51 Ko) Télécharger le fichier
Format : Figure, Image
inria-00388481 , version 1 (26-05-2009)
Bruce Walter, Shuang Zhao, Nicolas Holzschuch, Kavita Bala. Single Scattering in Refractive Media with Triangle Mesh Boundaries. ACM Transactions on Graphics, 2009, 28 (3), pp.92:1-8. ⟨10.1145/1531326.1531398⟩. ⟨inria-00388481⟩
474 Consultations
448 Téléchargements
