Increasing Reuse in Component Models through Genericity - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
A current limitation to component reusability is that component models target to describe a deployed assembly and thus bind the behavior of a component to the data-types it manipulates. This paper studies the feasibility of supporting genericity within component models, including component and port types. The proposed approach works by extending the meta-model of an existing component model. It is applied to the SCA component model; a working prototype shows its feasibility.
RR-6941.pdf (238.8 Ko) Télécharger le fichier
inria-00388508 , version 1 (27-05-2009)
  • HAL Id : inria-00388508 , version 1
Julien Bigot, Christian Pérez. Increasing Reuse in Component Models through Genericity. [Research Report] RR-6941, INRIA. 2009, pp.15. ⟨inria-00388508⟩
165 Consultations
207 Téléchargements
