Parallel Processes with Real-Time and Data: The ATLANTIF Intermediate Format - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Jan Stöcker
  • Fonction : Auteur
  • PersonId : 860858
Frederic Lang
Hubert Garavel
To model real-life critical systems, one needs ``high-level'' languages to express three important concepts: complex data structures, concurrency, and real-time. So far, the verification of timed systems has been successfully applied to ``low-level'' models, such as timed extensions of automata or of Petri nets. To bridge the gap between high-level languages, which allow a concise modeling of systems, and low-level models, for which efficient algorithms and tools have been designed, intermediate models are needed. In this article, we propose the ATLANTIF intermediate model, an extension with real-time and concurrency of the NTIF (New Technology Intermediate Format) intermediate model. We define the formal semantics of ATLANTIF and present a translator from ATLANTIF to timed automata (for verification using UPPAAL), and to time Petri nets (for verification using TINA).
RR-6950.pdf (395.61 Ko) Télécharger le fichier
Origine Fichiers produits par l'(les) auteur(s)
inria-00391024 , version 1 (03-06-2009)
  • HAL Id : inria-00391024 , version 1
Jan Stöcker, Frederic Lang, Hubert Garavel. Parallel Processes with Real-Time and Data: The ATLANTIF Intermediate Format. [Research Report] RR-6950, INRIA. 2009, pp.27. ⟨inria-00391024⟩
197 Consultations
276 Téléchargements
Gmail Mastodon Facebook X LinkedIn More
