A variance reduction technique using a quantized Brownian motion as a control variate - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2008
This article presents a new variance reduction technique for diffusion processes where a control variate is constructed using a quantization of the coefficients of the Karhunen-Loève decomposition of the underlying Brownian motion. This method may be indeed used for other Gaussian processes.
reduction-variance-quantization-2.pdf (268.69 Ko) Télécharger le fichier
inria-00393749 , version 1 (09-06-2009)
inria-00393749 , version 2 (18-04-2010)
inria-00393749 , version 3 (08-11-2010)
  • HAL Id : inria-00393749 , version 2
Antoine Lejay, Victor Reutenauer. A variance reduction technique using a quantized Brownian motion as a control variate. 2008. ⟨inria-00393749v2⟩
334 Consultations
534 Téléchargements
