Toward Autonomic Grids: Analyzing the Job Flow with Affinity Streaming - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Xiangliang Zhang
  • Fonction : Auteur
  • PersonId : 849671
Cyril Furtlehner
  • Fonction : Auteur
  • PersonId : 849672
Julien Perez
  • Fonction : Auteur
  • PersonId : 849670
Cécile Germain
Michèle Sebag
  • Fonction : Auteur
  • PersonId : 836537
The Affinity Propagation (AP) clustering algorithm proposed by Frey and Dueck (2007) provides an understandable, nearly optimal summary of a dataset, albeit with quadratic computational complexity. This paper, motivated by Autonomic Computing, extends AP to the data streaming framework. Firstly a hierarchical strategy is used to reduce the complexity to O( N^(1+e) ); the distortion loss incurred is analyzed in relation with the dimension of the data items. Secondly, a coupling with a change detection test is used to cope with non-stationary data distribution, and rebuild the model as needed. The presented approach StrAP is applied to the stream of jobs submitted to the EGEE Grid, providing an understandable description of the job flow and enabling the system administrator to spot online some sources of failures.
sub_sigkdd_v3.pdf (355.64 Ko) Télécharger le fichier
inria-00393825 , version 1 (09-06-2009)
  • HAL Id : inria-00393825 , version 1
Xiangliang Zhang, Cyril Furtlehner, Julien Perez, Cécile Germain, Michèle Sebag. Toward Autonomic Grids: Analyzing the Job Flow with Affinity Streaming. 15th ACM SIGKDD Conference on Knowledge Discovery and Data Mining (KDD), Jun 2009, Paris, France. ⟨inria-00393825⟩
255 Consultations
182 Téléchargements
