On the burstiness of visual elements
Burstiness, a phenomenon initially observed in text retrieval, is the property that a given visual element appears more times in an image than a statistically independent model would predict. In the context of image search, burstiness corrupts the visual similarity measure, i.e., the scores used to rank the images. In this paper, we propose a strategy to handle visual bursts for bag-of-features based image search systems. Experimental results on three reference datasets show that our method significantly and consistently outperforms the state of the art.
jegou_burstiness.pdf (2.63 Mo)
Télécharger le fichier
jegou_burstiness_poster.pdf (26.63 Mo)
Format : Other
