Conditional mixed-state model for structural change analysis from very high resolution optical images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
The present work concerns the analysis of dynamic scenes from earth observation images. We are interested in building a map which, on one hand locates places of change, on the other hand, reconstructs a unique visual information of the non-change areas. We show in this paper that such a problem can naturally be takled with conditional mixed-state random field modeling (mixed-state CRF), where the "mixed state" refers to the symbolic or continous nature of the unknown variable. The maximum a posteriori (MAP) estimation of the CRF is, through the Hammersley-Clifford theorem, turned into an energy minimisation problem. We tested the model on several Quickbird images and illustrate the quality of the results.
belmudez-igarss09-crp3376.pdf (133.27 Ko) Télécharger le fichier
inria-00398062 , version 1 (24-06-2009)
  • HAL Id : inria-00398062 , version 1
Benjamin Belmudez, Veronique Prinet, Jian-Feng Yao, Patrick Bouthemy, Xavier Descombes. Conditional mixed-state model for structural change analysis from very high resolution optical images. 2009 IEEE International Geosciences and Remote Sensing Symposium, Jul 2009, Cape Town, South Africa. ⟨inria-00398062⟩
383 Consultations
223 Téléchargements
