Automatic translation of C/C++ parallel code into synchronous formalism using an SSA intermediate form - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
We present an approach for the translation of imperative code (like C, C++) into the synchronous formalism \signal, in order to use a model-checker to verify properties on the source code. The translation uses ßa\ as an intermediate formalism, and the GCC compiler as a front-end. The contributions of this paper with respect to previous work are a more efficient translation scheme, and the management of parallel code. It is applied successfully on simple \systemc\ examples.
RR-6976.pdf (273.48 Ko) Télécharger le fichier
inria-00400272 , version 1 (30-06-2009)
  • HAL Id : inria-00400272 , version 1
Loïc Besnard, Thierry Gautier, Matthieu Moy, Jean-Pierre Talpin, Kenneth Johnson, et al.. Automatic translation of C/C++ parallel code into synchronous formalism using an SSA intermediate form. [Research Report] RR-6976, INRIA. 2009, pp.16. ⟨inria-00400272⟩
543 Consultations
248 Téléchargements
