Volumetric Billboards - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Computer Graphics Forum Année : 2009
We introduce an image-based representation, called volumetric billboards, allowing for the real-time rendering of semi-transparent and visually complex objects arbitrarily distributed in a 3D scene. Our representation offers full parallax effect from any viewing direction and improved anti-aliasing of distant objects. It correctly handles transparency between multiple and possibly overlapping objects without requiring any primitive sorting. Furthermore, volumetric billboards can be easily integrated into common rasterization-based renderers, which allows for their concurrent use with polygonal models and standard rendering techniques such as shadow-mapping. The representation is based on volumetric images of the objects and on a dedicated real-time volume rendering algorithm that takes advantage of the GPU geometry shader. Our examples demonstrate the applicability of the method in many cases including levels-of-detail representation for multiple intersecting complex objects, volumetric textures, animated objects and construction of high-resolution objects by assembling instances of lowresolution volumetric billboards.
VolumetricBillboards_CGF09.pdf (8.21 Mo) Télécharger le fichier
VolumetricBillboards.avi (53.1 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
inria-00402067 , version 1 (28-04-2011)
Philippe Decaudin, Fabrice Neyret. Volumetric Billboards. Computer Graphics Forum, 2009, 28 (8), pp.2079-2089. ⟨10.1111/j.1467-8659.2009.01354.x⟩. ⟨inria-00402067⟩
2039 Consultations
2457 Téléchargements
