Twinned Meshes for Dynamic Triangulation of Implicit Surfaces - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2007
We introduce a new approach to mesh an animated implicit surface for rendering. Our contribution is a method which solves stability issues of implicit triangulation, in the scope of real-time rendering. This method is robust, moreover it provides interactive and quality rendering of animated or manipulated implicit surfaces. This approach is based on a double triangulation of the surface, a mechanical one and a geometric one. In the first triangulation, the vertices are the nodes of a simplified mechanical finite element model. The aim of this model is to uniformly and dynamically sample the surface. It is robust, efficient and prevents the inversion of triangles. The second triangulation is dynamically created from the first one at each frame. It is used for rendering and provides details in regions of high curvature. We demonstrate this technique with skeleton-based and volumetric animated surfaces.
twinned.pdf (2.07 Mo) Télécharger le fichier
BN07.avi (33.44 Mo) Télécharger le fichier
Format : Figure, Image
Format : Vidéo
inria-00402094 , version 1 (20-05-2011)
Antoine Bouthors, Matthieu Nesme. Twinned Meshes for Dynamic Triangulation of Implicit Surfaces. GI '07 - Graphics Interface, May 2007, Montréal, Canada. pp.3-9, ⟨10.1145/1268517.1268521⟩. ⟨inria-00402094⟩
216 Consultations
308 Téléchargements
