Variational approximation for detecting points-like target problems - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Daniele Graziani
  • Fonction : Auteur
  • PersonId : 861740
Gilles Aubert
  • Fonction : Auteur
  • PersonId : 841269
The aim of this report is to provide a variational formulation for the detection of points in $2$-d biological images. To this purpose we introduce a new functional of the calculus of variation whose minimizers gives the points we want to detect. Then we build an approximating sequence of functional, for which we prove the $\Gamma$-convergence to the initial one.
RR-6987.pdf (393.47 Ko) Télécharger le fichier
inria-00403232 , version 1 (09-07-2009)
inria-00403232 , version 2 (10-07-2009)
inria-00403232 , version 3 (16-11-2009)
  • HAL Id : inria-00403232 , version 2
Daniele Graziani, Gilles Aubert. Variational approximation for detecting points-like target problems. [Research Report] RR-6987., 2009, pp.35. ⟨inria-00403232v2⟩
Collections
INRIA-RRRT
266 Consultations
106 Téléchargements
