Sens, synonymes et définitions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
We present a method for grouping the synonyms of a word into sets representing the possible meanings of that word. The possible meanings are given by the definitions of a general dictionary for French, the TLFi (Trésor de la langue française informatisé) and the method is applied to the synonyms of 5 synonym dictionnaries. To evaluate the method, we manually constructed a gold standard where for each (word, definition) pair, 4 lexicographers specified the set of synonyms they judge adequate. The method scores an F-measure of 0.602 when no distinction is made between pronominal and non-pronominal use and 0.706 when it is.
falketal-taln09-finalisee.pdf (359.67 Ko) Télécharger le fichier
taln09.slides.pdf (456.21 Ko) Télécharger le fichier
Format : Autre
inria-00403572 , version 1 (10-07-2009)
  • HAL Id : inria-00403572 , version 1
Ingrid Falk, Claire Gardent, Evelyne Jacquey, Fabienne Venant. Sens, synonymes et définitions. Conférence sur le Traitement Automatique du Langage Naturel - TALN'2009, Laboratoire d'Informatique de Paris-Nord, Université Paris 13 & CNRS (LIPN), Jun 2009, Senlis, France. ⟨inria-00403572⟩
278 Consultations
12436 Téléchargements
