Scaling limit of a discrete prion dynamics model - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Communications in Mathematical Sciences Année : 2009
This paper investigates the connection between discrete and continuous models describing prion proliferation. The scaling parameters are interpreted on biological grounds and we establish rigorous convergence statements. We also discuss, based on the asymptotic analysis, relevant boundary conditions that can be used to complete the continuous model.
Scaling_limit_2009_07_05.pdf (282.55 Ko) Télécharger le fichier
inria-00403914 , version 1 (13-07-2009)
Marie Doumic, Thierry Goudon, Thomas Lepoutre. Scaling limit of a discrete prion dynamics model. Communications in Mathematical Sciences, 2009, 7 (4), ⟨10.4310/CMS.2009.v7.n4.a3⟩. ⟨inria-00403914⟩
508 Consultations
433 Téléchargements
