VoIP Malware: Attack Tool & Attack Scenarios - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
With the appearance of new Internet services like Voice over IP and IP television, malwares are in the way to update and extend their targets. In this paper, we discuss the emergence of a new generation of malwares attacking VoIP infrastructures and services. Such malwares constitute a real threat to the currently deployed VoIP architectures without strong security measures in place. We present one implemented environment that can be used to evaluate such attacks. Our ``VoIP bots'' support a wide set of attacks ranging from SPIT to DDoS and are tested against several VoIP platforms.
main.pdf (323.89 Ko) Télécharger le fichier
inria-00404837 , version 1 (17-07-2009)
  • HAL Id : inria-00404837 , version 1
Mohamed Nassar, Radu State, Olivier Festor. VoIP Malware: Attack Tool & Attack Scenarios. IEEE ICC 09, IEEE, Jun 2009, Dresden, Germany. pp.1-6. ⟨inria-00404837⟩
199 Consultations
1634 Téléchargements
