Remote and Collaborative 3D Interactions - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Real-time multi-camera 3D modeling provides full-body geometric and photometric data on the objects present in the acquisition space. It can be used as an input device for rendering textured 3D models, and for computing interactions with virtual objects through a physical simulation engine. In this paper we present a work in progress to build a collaborative environment where two distant users, each one 3D modeled in real-time, interact in a shared virtual world.
petit-3DTV-CON-2009.pdf (605.32 Ko) Télécharger le fichier
Format : Figure, Image
inria-00405810 , version 1 (21-07-2009)
Benjamin Petit, Jean-Denis Lesage, Edmond Boyer, Jean-Sébastien Franco, Bruno Raffin. Remote and Collaborative 3D Interactions. 3DTV 2009 - The True Vision - Capture, Transmission and Display of 3D Video, May 2009, Potsdam, Germany. pp.1-4, ⟨10.1109/3DTV.2009.5069651⟩. ⟨inria-00405810⟩
380 Consultations
376 Téléchargements
