s'authentifier
version française rss feed
inria-00406450, version 1
Self-adaptive web intrusion detection system
Thomas Guyet (Auteur à contacter de préférence) a12, René Quiniou b1, Wei Wang 3, Marie-Odile Cordier () c1
N° RR-6989 (2009)
Résumé : The evolution of the web server contents and the emergence of new kinds of intrusions make necessary the adaptation of the intrusion detection systems (IDS). Nowadays, the adaptation of the IDS requires manual -- tedious and unreactive -- actions from system administrators. In this paper, we present a self-adaptive intrusion detection system which relies on a set of local model-based diagnosers. The redundancy of diagnoses is exploited, online, by a meta-diagnoser to check the consistency of computed partial diagnoses, and to trigger the adaptation of defective diagnoser models (or signatures) in case of inconsistency. This system is applied to the intrusion detection from a stream of HTTP requests. Our results show that our system 1) detects intrusion occurrences sensitively and precisely, 2) accurately self-adapts diagnoser model, thus improving its detection accuracy.
  • Domaine : Informatique/Réseaux et télécommunications
    Informatique/Système multi-agents
    Informatique/Intelligence artificielle
  • Mots-clés : intrusion detection – self-adaptive diagnosis – meta-diagnosis – self-adaptive system – web application intrusion
  • Référence interne : RR-6989
  • inria-00406450, version 1
  • oai:hal.inria.fr:inria-00406450
  • Contributeur :
  • Soumis le : Mercredi 22 Juillet 2009, 12:34:28
  • Dernière modification le : Vendredi 5 Mars 2010, 12:51:34
tous les articles de la base du CCSd...
