Self-adaptive web intrusion detection system - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
The evolution of the web server contents and the emergence of new kinds of intrusions make necessary the adaptation of the intrusion detection systems (IDS). Nowadays, the adaptation of the IDS requires manual -- tedious and unreactive -- actions from system administrators. In this paper, we present a self-adaptive intrusion detection system which relies on a set of local model-based diagnosers. The redundancy of diagnoses is exploited, online, by a meta-diagnoser to check the consistency of computed partial diagnoses, and to trigger the adaptation of defective diagnoser models (or signatures) in case of inconsistency. This system is applied to the intrusion detection from a stream of HTTP requests. Our results show that our system 1) detects intrusion occurrences sensitively and precisely, 2) accurately self-adapts diagnoser model, thus improving its detection accuracy.
RR-6989.pdf (555.63 Ko) Télécharger le fichier
inria-00406450 , version 1 (22-07-2009)
  • HAL Id : inria-00406450 , version 1
  • ARXIV : 0907.3819
Thomas Guyet, René Quiniou, Wei Wang, Marie-Odile Cordier. Self-adaptive web intrusion detection system. [Research Report] RR-6989, INRIA. 2009, pp.24. ⟨inria-00406450⟩
442 Consultations
2317 Téléchargements
