Explicit Runge-Kutta Residual Distribution schemes for Time Dependent Problems~: second order case - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
In this paper we construct spatially consistent second order explicit discretizations for time dependent hyperbolic problems, starting from a given Residual Distribution (RD) discrete approximation of the steady operator. We explore the properties of the RD mass matrices necessary to achieve consistency in space, and finally show how to make use of second order mass lumping to obtain second order explicit schemes. The discussion is particularly relevant for schemes of the residual distribution type which we will use for all our numerical experiments. However, similar ideas can be used in the context of residual based finite volume discretizations.
RR-6998.pdf (25.5 Mo) Télécharger le fichier
inria-00406958 , version 1 (23-07-2009)
inria-00406958 , version 2 (24-07-2009)
inria-00406958 , version 3 (25-07-2009)
  • HAL Id : inria-00406958 , version 2
Mario Ricchiuto, Remi Abgrall. Explicit Runge-Kutta Residual Distribution schemes for Time Dependent Problems~: second order case. [Research Report] RR-6998, 2009. ⟨inria-00406958v2⟩
Collections
INRIA-RRRT
331 Consultations
263 Téléchargements
