Construction of Büchi Automata for LTL Model Checking Verified in Isabelle/HOL - Inria - Institut national de recherche en sciences et technologies du numérique Access content directly
Conference Papers Year : 2009
Alexander Schimpf
  • Function : Author
Jan-Georg Smaus
We present the implementation in Isabelle/HOL of a translation of LTL formulae into Büchi automata. In automaton-based model checking, systems are modelled as transition systems, and correctness properties stated as formulae of temporal logic are translated into corresponding automata. An LTL formula is represented by a (generalised) Büchi automaton that accepts precisely those behaviours allowed by the formula. The model checking problem is then reduced to checking language inclusion between the two automata. The automaton construction is thus an essential component of an LTL model checking algorithm. We implemented a standard translation algorithm due to Gerth et al. The correctness and termination of our implementation are proven in Isabelle/HOL, and executable code is generated using the Isabelle/HOL code generator.
Dates and versions
inria-00408950 , version 1 (04-08-2009)
Identifiers
Cite
Alexander Schimpf, Stephan Merz, Jan-Georg Smaus. Construction of Büchi Automata for LTL Model Checking Verified in Isabelle/HOL. 22nd International Conference Theorem Proving in Higher-Order Logics - TPHOLs 2009, Aug 2009, Munich, Germany. pp.424-439, ⟨10.1007/978-3-642-03359-9_29⟩. ⟨inria-00408950⟩
138 View
0 Download
Share
Gmail Mastodon Facebook X LinkedIn More
