A 802.11g and UMTS Simultaneous Reception Front-End Architecture using a double IQ structure
In this paper, we address the architecture of multistandard simultaneous reception receivers and we aim to reduce the complexity of the analog front-end. To this end, we propose an architecture using the double orthogonal translation technique in order to multiplex two signals received on different frequency bands. A study case concerning the simultaneous reception of 802.11g and UMTS signals is developed in this paper. Theoretical and simulation results show that this type of multiplexing does not significantly influence the evolution of the signal to noise ratio of the signals.
