IQ imbalance reduction in a SMI multi-antenna receiver by using a code multiplexing front-end - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
In this paper, we address the IQ imbalance sensibility of the code multiplexing front-end architecture. This innovative architecture has been recently proposed in order to reduce the analog complexity of an antenna diversity receiver front-end. An interesting characteristic of this structure is that the resulting IQ imbalance is equal for each received baseband signal. Associated with Single Matrix Inversion algorithm, this property ensures a high IQ imbalance robustness. A global antenna diversity system including analog front-end and digital processing has been implemented in order to perform simulation validation. Results show that the bit error rate does not increase significantly with the multiplexing and this increase is compensated for a high IQ imbalance.
VTC_spring09.pdf (518.4 Ko) Télécharger le fichier
inria-00412044 , version 1 (27-11-2009)
  • HAL Id : inria-00412044 , version 1
Matthieu Gautier, Pierre-Francois Morlat, Guillaume Villemaud. IQ imbalance reduction in a SMI multi-antenna receiver by using a code multiplexing front-end. IEEE VTC Spring 2009, Apr 2009, Barcelona, Spain. ⟨inria-00412044⟩
209 Consultations
188 Téléchargements
