Isotropic Surface Remeshing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2003
This paper proposes a new method for isotropic remeshing of tri- angulated surface meshes. Given a triangulated surface mesh to be resampled and a user-specified density function defined over it, we first distribute the desired number of samples by generalizing error diffusion, commonly used in image halftoning, to work directly on mesh triangles and feature edges. We then use the resulting sam- pling as an initial configuration for building a weighted centroidal Voronoi tessellation in a conformal parameter space, where the specified density function is used for weighting. We finally create the mesh by lifting the corresponding constrained Delaunay trian- gulation from parameter space. A precise control over the sampling is obtained through a flexible design of the density function, the latter being possibly low-pass filtered to obtain a smoother grada- tion. We demonstrate the versatility of our approach through vari- ous remeshing examples.
isotropic.pdf (7.61 Mo) Télécharger le fichier
inria-00413144 , version 1 (03-09-2009)
  • HAL Id : inria-00413144 , version 1
Pierre Alliez, Éric Colin de Verdière, Olivier Devillers, Martin Isenburg. Isotropic Surface Remeshing. International Conference on Shape Modeling and applications,, May 2003, Seoul, South Korea. ⟨inria-00413144⟩
275 Consultations
609 Téléchargements
