Computing the Maximum Overlap of Two Convex Polygons Under Translations. - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Theory of Computing Systems Année : 1998
Let P be a convex polygon in the plane with n vertices and let Q be a convex polygon with m vertices. We prove that the maximum number of combinatorially distinct placements of Q with respect to P under translations is O(n^2+m^2+min(nm^2+n^2m)), and we give an example showing that this bound is tight in the worst case. Second, we present an O((n+m)log(n+m)) algorithm for determining a translation of Q that maximizes the area of overlap of P and Q. We also prove that the position which translates the centroid of Q on the centroid of P always realizes an overlap of 9/25 of the maximum overlap and that this overlap may be as small as 4/9 of the maximum.
bcdkt-cmotc-98.pdf (243.96 Ko) Télécharger le fichier
inria-00413175 , version 1 (03-09-2009)
Mark De Berg, Olivier Devillers, Marc Van Kreveld, Otfried Schwarzkopf, Monique Teillaud. Computing the Maximum Overlap of Two Convex Polygons Under Translations.. Theory of Computing Systems, 1998, 31, pp.613-628. ⟨10.1007/PL00005845⟩. ⟨inria-00413175⟩
160 Consultations
288 Téléchargements
