Dynamic location in an arrangement of line segments in the plane - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Algorithms Review - newsletter of the ESPRIT II Basic Research Action Project no. 3075 (ALCOM) Année : 1992
We describe in this paper an algorithm which dynamically maintains the trapezoidal map of an arrangement of line segments. This algorithm is a generalization of the Influence Graph data structure used by Boissonnat et al. to deal with the semi-dynamic case. Our complexity results are randomized, i.e. the insertion sequences are supposed to be evenly distributed among the n! possible sequences of $ segments, and when an object is deleted, we suppose that it can be any of the already inserted objects with the same probability. Under these assumptions the algorithm needs O(n+a) expected space, O(log n + a/n) expected insertion time, O( (1+ a/n)loglog n) expected deletion time and O(log n) time to locate any query point in the arrangement, where a is the current size of the arrangement and n the current number of segments.
alg-review.pdf (1.36 Mo) Télécharger le fichier
inria-00413506 , version 1 (04-09-2009)
  • HAL Id : inria-00413506 , version 1
Olivier Devillers, Monique Teillaud, Mariette Yvinec. Dynamic location in an arrangement of line segments in the plane. Algorithms Review - newsletter of the ESPRIT II Basic Research Action Project no. 3075 (ALCOM) , 1992, 2 (3), pp.89-103. ⟨inria-00413506⟩
228 Consultations
66 Téléchargements
