User Assisted Intrinsic Images - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue ACM Transactions on Graphics Année : 2009
Sylvain Paris
  • Fonction : Auteur
  • PersonId : 863035
Frédo Durand
  • Fonction : Auteur
  • PersonId : 856519
For many computational photography applications, the lighting and materials in the scene are critical pieces of information. We seek to obtain intrinsic images, which decompose a photo into the product of an illumination component that represents lighting effects and a reflectance component that is the color of the observed material. This is an under-constrained problem and automatic methods are challenged by complex natural images. We describe a new approach that enables users to guide an optimization with simple indications such as regions of constant reflectance or illumination. Based on a simple assumption on local reflectance distributions, we derive a new propagation energy that enables a closed form solution using linear least-squares. We achieve fast performance by introducing a novel downsampling that preserves local color distributions. We demonstrate intrinsic image decomposition on a variety of images and show applications.
intrinsic_main.pdf (797.53 Ko) Télécharger le fichier
intrinsic_video.mov (32 B) Télécharger le fichier
Format : Figure, Image
Format : Autre
inria-00413588 , version 1 (04-10-2009)
inria-00413588 , version 2 (25-11-2009)
  • HAL Id : inria-00413588 , version 1
Adrien Bousseau, Sylvain Paris, Frédo Durand. User Assisted Intrinsic Images. ACM Transactions on Graphics, 2009, Proceedings of SIGGRAPH Asia 2009, 28 (5). ⟨inria-00413588v1⟩
310 Consultations
506 Téléchargements
