Automatic performance modelling of black boxes targetting self-sizing - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Modern distributed systems are characterized by a growing complexity of their architecture, functionalities and workload. This complexity, and in particular significant workloads, often lead to quality of service loss, saturation and sometimes unavailability of on-line services. To avoid troubles caused by important workloads and fulfill a given level of quality of service (such as response time), systems need to \emph{self-manage}, for instance by tuning or strengthening one tier through replication. This autonomic feature requires performance modelling of systems. In this objective, we developed an automatic identification process providing a queuing model for a part of distributed system considered as black box. This process is a part of a general approach targetting self-sizing for distributed systems and is based on a theoretical and experimental approach. In this report, we show how to derive automatically the performance model of one black box considered as a constituent of a distributed system, starting from load injection experiments. This model is determined progressively, using self-regulated test injections, from statistical analysis of measured metrics, namely response time. This process is illustrated through experimental results.
RR-7027.pdf (728.15 Ko) Télécharger le fichier
inria-00413935 , version 1 (07-09-2009)
  • HAL Id : inria-00413935 , version 1
Ahmed Harbaoui, Nabila Salmi, Bruno Dillenseger, Jean-Marc Vincent. Automatic performance modelling of black boxes targetting self-sizing. [Research Report] RR-7027, INRIA. 2009, pp.19. ⟨inria-00413935⟩
292 Consultations
107 Téléchargements
