Improved stability conditions for sampled data systems with jitter - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
This paper is concerned with the discrete time approach for the robust stability of sampled-data systems (Astrom and Wittenmark 1997) with sampling jitter. We assume that the sampling is unknown, time-varying and bounded in a given interval. Several discrete-timea pproaches exist in the literature. The intention of the paper is to clearly analyse the relations between them and to indicate the sources of conservatism. It will point out that the different existing models can be studied in the framework of difference inclusions with polytopic and norm bounded components. Furthermore, it will show how to reduce the conservatisms by using recent stability analysis tools based on Lyapunov functions with non-monotonic Lyapunov increment. The idea is to improve the stability conditions by considering α-samples variations, i.e. $V (x_{k+α}) − V (x_{k}) < 0$. Numerical examples illustrate the effectiveness of the approach.
Automatique
Fichier non déposé
inria-00419438 , version 1 (23-09-2009)
  • HAL Id : inria-00419438 , version 1
Laurentiu Hetel, Alexandre Kruszewski, Thierry-Marie Guerra, Jean-Pierre Richard. Improved stability conditions for sampled data systems with jitter. ROCOND'09, 6th IFAC Symposium on Robust Control Design, Jun 2009, Haifa, Israel. ⟨inria-00419438⟩
214 Consultations
0 Téléchargements
