Landscape regularity modelling for environmental challenges in agriculture - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Landscape Ecology Année : 2009
In agricultural landscapes, methods to identify and describe meaningful landscape patterns play an important role to understand the interaction between landscape organization and ecological processes. We propose an innovative stochastic modelling method of agricultural landscape organization where the temporal regularities in land-use are first identified through recognized Land-Use Successions (LUS) before locating these successions in landscapes. These time-space regularities within landscapes are extracted using a new data mining method based on Hidden Markov Models. We applied this methodological proposal to the Niort Plain (West of France). We built a temporo-spatial analysis for this case study through spatially explicit analysis of Land Use Succession (LUS) dynamics. Implications and perspectives of such an approach, which links together the temporal and the spatial dimensions of the agricultural organization, are discussed by assessing the relationship between the agricultural landscape patterns defined using this approach and ecological data through an illustrative example of bird nests.
LAZRAK-MARI-BENOIT-23July09.pdf (2.08 Mo) Télécharger le fichier
inria-00419952 , version 1 (25-09-2009)
El Ghali Lazrak, Jean-Francois Mari, Benoît Marc. Landscape regularity modelling for environmental challenges in agriculture. Landscape Ecology, 2009, Landscape Ecology, 25 (2), pp.169-183. ⟨10.1007/s10980-009-9399-8⟩. ⟨inria-00419952⟩
225 Consultations
366 Téléchargements
