Bringing Introspection Into the BlobSeer Data-Management System Using the MonALISA Distributed Monitoring Framework - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
Jing Cai
  • Fonction : Auteur
  • PersonId : 862678
Gabriel Antoniu
Luc Bougé
Introspection is the prerequisite of an autonomic behavior, the first step towards a performance improvement and a resource-usage optimization for large-scale distributed systems. In grid environments, the task of observing the application behavior is assigned to monitoring systems. However, most of them are designed to provide general resource information and do not consider specific information for higher-level services. More specifically, in the context of data-intensive applications, a specific introspection layer is required in order to collect data about the usage of storage resources, about data access patterns, etc. This paper discusses the requirements for an introspection layer in a data-management system for large-scale distributed infrastructures. We focus on the case of BlobSeer, a large-scale distributed system for storing massive data. The paper explains why and how to enhance BlobSeer with introspective capabilities and proposes a three-layered architecture relying on the MonALISA monitoring framework. This approach has been evaluated on the Grid'5000 testbed, with experiments that prove the feasibility of generating relevant information related to the state and the behavior of the system.
RR-7043.pdf (260.61 Ko) Télécharger le fichier
inria-00419978 , version 1 (25-09-2009)
inria-00419978 , version 2 (23-11-2009)
  • HAL Id : inria-00419978 , version 1
Alexandra Carpen-Amarie, Jing Cai, Alexandru Costan, Gabriel Antoniu, Luc Bougé. Bringing Introspection Into the BlobSeer Data-Management System Using the MonALISA Distributed Monitoring Framework. [Research Report] RR-7043, 2009, pp.11. ⟨inria-00419978v1⟩
Collections
INRIA-RRRT
407 Consultations
309 Téléchargements
