The Attributed Pi Calculus with Priorities - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Chapitre D'ouvrage Année : 2010
We present the attributed $\pi$-calculus for modeling concurrent systems with interaction constraints depending on the values of attributes of processes. The $\pi$-calculus serves as a constraint language underlying the $\pi$-calculus. Interaction constraints subsume priorities, by which to express global aspects of populations. We present a nondeterministic and a stochastic semantics for the attributed $\pi$-calculus. We show how to encode the $\pi$-calculus with priorities and polyadic synchronization $\pi$@ and thus dynamic compartments, as well as the stochastic $\pi$-calculus with concurrent objects spico. We illustrate the usefulness of the attributed $\pi$-calculus for modeling biological systems at two particular examples: Euglena’s spatial movement in phototaxis, and cooperative protein binding in gene regulation of bacteriophage lambda. Furthermore, population-based model is supported beside individual-based modeling. A stochastic simulation algorithm for the attributed $\pi$-calculus is derived from its stochastic semantics. We have implemented a simulator and present experimental results, that confirm the practical relevance of our approach.
final.pdf (570.23 Ko) Télécharger le fichier
inria-00422969 , version 1 (02-11-2009)
Mathias John, Cédric Lhoussaine, Joachim Niehren, Adelinde Uhrmacher. The Attributed Pi Calculus with Priorities. Corrado Priami; Rainer Breitling; David Gilbert; Monika Heiner; Adelinde M. Uhrmacher. Transactions on Computational Systems Biology XII: Special Issue on Modeling Methodologies, LNBI-5945, Springer, pp.13-76, 2010, Lecture Notes in Bioinformatics (Journal Subline), 978-3-642-11712-1. ⟨10.1007/978-3-642-11712-1_2⟩. ⟨inria-00422969⟩
212 Consultations
250 Téléchargements
