Toward a multiple impact law: the 3-ball chain example
The aim of this work is to exhibit a multiple impact law for rigid body dynamical system which meets the properties of closing the non-smooth dynamical equations and of corroborating experiments. This law is based on the impulse correlation ratio which is computed from equivalent regularized model with compliant contact. A case-study on 3-ball chain and -ball chain are delineated and results on finite dimensional system are stated.
