Towards A Grid File System Based On A Large-Scale BLOB Management Service - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 2009
Viet-Trung Tran
  • Fonction : Auteur
  • PersonId : 864088
Gabriel Antoniu
Bogdan Nicolae
  • Fonction : Auteur
  • PersonId : 862774
Luc Bougé
This paper addresses the problem of building a grid file system for applications that need to manipulate huge data, distributed and concurrently accessed at a very large scale. In this paper we explore how this goal could be reached through a cooperation between the Gfarm grid file system and BlobSeer, a distributed object management system specifically designed for huge data management under heavy concurrency. The resulting BLOB-based grid file system exhibits scalable file access performance in scenarios where huge files are subject to massive, concurrent, fine-grain accesses. This is demonstrated through preliminary experiments of our prototype, conducted on the Grid'5000 testbed.
main.pdf (267.01 Ko) Télécharger le fichier
2009-08-24-CoreGRID-2.pdf (9.73 Mo) Télécharger le fichier
Format : Autre
inria-00425232 , version 1 (20-10-2009)
inria-00425232 , version 2 (22-10-2009)
inria-00425232 , version 3 (22-10-2009)
  • HAL Id : inria-00425232 , version 3
Viet-Trung Tran, Gabriel Antoniu, Bogdan Nicolae, Luc Bougé. Towards A Grid File System Based On A Large-Scale BLOB Management Service. CoreGRID ERCIM Working Group Workshop on Grids, P2P and Service computing, Aug 2009, Delft, Netherlands. ⟨inria-00425232v3⟩
329 Consultations
372 Téléchargements
