Numerical simulation of monuments by the contact dynamics method - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Communication Dans Un Congrès Année : 1998
The Non Smooth Contact dynamics Method (NSCD or CD) is presented in this paper. The purpose of this method is to deal with large collections of rigid or deformable bodies in contact with unilateral constraints and large friction. The method is applied to monuments made of blocks. The relevance of the modelling is discussed. Several examples of buildings statically an dynamically loaded are presented.
Lisbon98.pdf (287.05 Ko) Télécharger le fichier
inria-00425359 , version 1 (21-10-2009)
  • HAL Id : inria-00425359 , version 1
Vincent Acary, Michel Jean. Numerical simulation of monuments by the contact dynamics method. Monument-98, Workshop on seismic perfomance of monuments, Laboratório Nacional de engenharia Civil (LNEC), Lisboa, Portugal, Nov 1998, Lisbon, Portugal. pp.69-78. ⟨inria-00425359⟩
179 Consultations
216 Téléchargements
