Enrichissement des contenus par la réindexation des usagers : un état de l'art sur la problématique
Information retrieval (IR) is a user approach to obtain relevant information which meets needs with the help of a IR system (IRS). However, the IRS shows certain differences between user relevance and system relevance. These gaps are essentially related to the imperfection of the indexing process (as approach related to the IR), to problems related to the misunderstanding of the natural language and the non correspondence between the real needs of the user and the results of his query. As idea is to think about an “intellectual” indexing that takes into account the point of view of the user. By consulting the document, user can build information as added-value on the existing content: new information which grows contents and allows the semantic visibility or facilitates the reading by the annotations, by links to other content, by new descriptors, specific new abstracts of users: it is the reindexing of the contents by the contribution or the vote of the uses
