Analysis of the PSPG method for the transient Stokes' problem - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Rapport (Rapport De Recherche) Année : 2009
We propose a new analysis for the PSPG method applied to the transient Stokes' problem. Stability and convergence are obtained under different conditions on the discretization parameters depending on the approximation used in space. For the pressure we prove optimal stability and convergence only in the case of piecewise affine approximation under the standard condition on the time-step.
main.pdf (225.03 Ko) Télécharger le fichier
inria-00426777 , version 1 (27-10-2009)
inria-00426777 , version 2 (28-10-2009)
inria-00426777 , version 3 (12-04-2011)
  • HAL Id : inria-00426777 , version 1
Erik Burman, Miguel Angel Fernández. Analysis of the PSPG method for the transient Stokes' problem. [Research Report] RR-7074, 2009, pp.16. ⟨inria-00426777v1⟩
242 Consultations
644 Téléchargements
