Combination of Convex Theories: Modularity, Deduction Completeness, and Explanation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Journal of Symbolic Computation Année : 2010
Decision procedures are key components of theorem provers and constraint satisfaction systems. Their modular combination is of prime interest for building efficient systems, but their effective use is often limited by poor interface capabilities, when such procedures only provide a simple “sat/unsat” answer. In this paper, we develop a framework to design cooperation schemas between such procedures while maintaining modularity of their interfaces. First, we use the framework to specify and prove the correctness of classic combination schemas by Nelson–Oppen and Shostak. Second, we introduce the concept of deduction complete satisfiability procedures, we show how to build them for large classes of theories, then we provide a schema to modularly combine them. Third, we consider the problem of modularly constructing explanations for combinations by re-using available proof-producing procedures for the component theories.
inria-00428583 , version 1 (29-10-2009)
Duc-Khanh Tran, Christophe Ringeissen, Silvio Ranise, Hélène Kirchner. Combination of Convex Theories: Modularity, Deduction Completeness, and Explanation. Journal of Symbolic Computation, 2010, Automated Deduction: Decidability, Complexity, Tractability, 45 (2), pp.261-286. ⟨10.1016/j.jsc.2008.10.006⟩. ⟨inria-00428583⟩
137 Consultations
0 Téléchargements
