Convolution Surfaces based on Polygonal Curve Skeletons. (An Application of Symbolic Integration to Graphics) - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Pré-Publication, Document De Travail Année : 2010
This paper reviews and generalizes Convolution Surfaces, a technique used in Computer Graphics to generate smooth 3D volumes around skeletons that are lower dimensional or simpler geometric models of the shape to be created. Convolution surfaces are defined as level sets of a function obtained by integrating a kernel function along this skeleton. To allow interactive modeling, the technique has relied on closed form formulae for integration obtained through symbolic computation software.
HubertCaniApril7.pdf (1.17 Mo) Télécharger le fichier
inria-00429358 , version 1 (02-11-2009)
inria-00429358 , version 2 (30-04-2010)
inria-00429358 , version 3 (17-11-2010)
  • HAL Id : inria-00429358 , version 2
Evelyne Hubert, Marie-Paule Cani. Convolution Surfaces based on Polygonal Curve Skeletons. (An Application of Symbolic Integration to Graphics). 2010. ⟨inria-00429358v2⟩
388 Consultations
938 Téléchargements
