hwloc: a Generic Framework for Managing Hardware Affinities in HPC Applications - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
The increasing numbers of cores, shared caches and memory nodes within machines introduces a complex hardware topology. High-performance computing applications now have to carefully adapt their placement and behavior according to the underlying hierarchy of hardware resources and their software affinities. We introduce the Hardware Locality (hwloc) software which gathers hardware information about processors, caches, memory nodes and more, and exposes it to applications and runtime systems in a abstracted and portable hierarchical manner. hwloc may significantly help performance by having runtime systems place their tasks or adapt their communication strategies depending on hardware affinities. We show that hwloc can already be used by popular high-performance OpenMP or MPI software. Indeed, scheduling OpenMP threads according to their affinities or placing MPI processes according to their communication patterns shows interesting performance improvement thanks to hwloc. An optimized MPI communication strategy may also be dynamically chosen according to the location of the communicating processes in the machine and its hardware characteristics.
main.pdf (109.92 Ko) Télécharger le fichier
inria-00429889 , version 1 (04-11-2009)
François Broquedis, Jérôme Clet-Ortega, Stéphanie Moreaud, Nathalie Furmento, Brice Goglin, et al.. hwloc: a Generic Framework for Managing Hardware Affinities in HPC Applications. PDP 2010 - The 18th Euromicro International Conference on Parallel, Distributed and Network-Based Computing, Feb 2010, Pisa, Italy. ⟨10.1109/PDP.2010.67⟩. ⟨inria-00429889⟩
1939 Consultations
1725 Téléchargements
