An incremental learning algorithm for functional approximation - Inria - Institut national de recherche en sciences et technologies du numérique Accéder directement au contenu
Article Dans Une Revue Advances in Engineering Software Année : 2009
This paper presents an incremental learning algorithm for feed-forward neural networks used as approximators of real world data. This algorithm allows neural networks of limited size to be obtained, providing better performances. The algorithm is compared to two of the main incremental algorithms (Dunkin and cascade correlation) in the respective contexts of synthetic data and of real data consisting of radiation doses in homogeneous environments.
inria-00430288 , version 1 (06-11-2009)
Jacques Bahi, Sylvain Contassot-Vivier, Marc Sauget. An incremental learning algorithm for functional approximation. Advances in Engineering Software, 2009, 40 (8), pp.725-730. ⟨10.1016/j.advengsoft.2008.12.018⟩. ⟨inria-00430288⟩
177 Consultations
0 Téléchargements
